MF35 Dual Clutch (Part 2)
Kris
03-19-2000 18:06:42
First of all having 2 different forums for the same model is confusing..... ..but I did get some info from the guys at the Harry Ferguson forum about how to tell if a TO-35 has live PTO. It was stated that the serial number would have an "M" if it was a dual stage clutch (live PTO) and an "F" if it was a standard clutch. Since the one I looked at has a serial number SGM-203004, I assume it has a dual clutch ....but I will try it out anyway.Is it easy to get used to pushing the clutch just half way down when doing PTO work such as mowing? Thanks for all of your comments!
Rod (WY)
03-20-2000 09:00:31
 Re: MF35 Dual Clutch (Part 2) in reply to Kris, 03-19-2000 18:06:42
The clutch also drives the hydraulic pump. Push the clutch down, the pump stops. There is live hydraulics on tractors with a two stage clutch but the pump will stop when the pedal is pushed all the way down.
B.C.
03-20-2000 06:01:17
Believe me, it gets to be second nature in a big hurry. If you ever drove something that didn't have live pto (especially on something like a baler) you'll very soon see the advance of that dual clutch. Just push the clutch pedal down halfway and there's no mistake about it.
Bob
03-19-2000 20:07:25
The two stage clutch is very easy to use
