MF135 stuck in low (dual range) gear
John Caldwell
03-15-2004 12:40:55
I have an early 60's model MF135 Intercontinental gas deluxe model with a dual range lever and multipower switch. My tractor's dual range lever is stuck in the low range position. I can't move it, and the tractor wont operate right now for some reason in the low range position...doesn't even feel like it was going into low when I moved it there this past weekend, even after using the tractor in low for several hours before it went out. Does anyone have any ideas on what may be wrong or have ideas for things I can check? thanks for any information you may have. JC
sibby.aus.
03-17-2004 05:03:30
 Re: MF135 stuck in low (dual range) gear in reply to John Caldwell, 03-15-2004 12:40:55
john,sounds like you may have a snapped selector fork or roll pin in selector.remove r.h.side plate (with. trans.dip stick ) and try to look at rear of g/box which has hi/lo reduction unit bolted to it.flashlight and mirror may help.try and move hi/lo/gearstick back and forth and see if selector moves in relation to it.if so,maybe shear tube which is located betweenrear of g/box anddifferential pinion could be sheared.this can be checked by removing l/h side plate with p.t.o.lever.hope this may help you,cheers.
Charlie
03-15-2004 17:33:21
You might check Big Dean's site at Link
