MF 245 rear pan gasket leak
Louie
03-15-2004 07:07:40
I think I have a rear pan gasket leak. It is leaking out of hole with cotter pin at bottom of transmission. It leaks when going up hill when loading onto my trailer. I just had the main rear seal replaced about 200 hours ago.
Do I have to split the tractor to replace the rear pan gasket? Is this a very complicated repair?
I appreciate any advice.
sibby(aus)
03-19-2004 15:33:49
 Re: MF 245 rear pan gasket leak in reply to Louie, 03-15-2004 07:07:40
guys,arent you worried oil may get onto clutch?louie,are you sure its the pan gasket,and not the rear main crank seal?gasket should last longer than 200 hrs.is your engine breather tube unrestricted?i might be a bit fussy maybe.cheers.
Hammer
03-15-2004 19:07:34
My 245 does the same thing & I've been told that's normal, as long as it's not leaking a lot. I get a few drops when it's parked only. The cotter pin is to keep the drainage hole open so it won't clog. Many years of trouble-free operation this way.
