MF50 Parts Wish List
Yooper-Al
03-14-2004 18:25:17
Has anyone had luck adding power steering to a MF-50? What more would be necessary than an after-market pump, cylinder(s), hoses and homemade mounts? Also, I would like to find a 2 or 3 spool remote (auxiliary control valve) for my MF-50. Lastly (for now), my tach cable is not connected to anything at the engine, and I suspect that the reason is because my Delco generator does not have a tach drive type rear bearing plate. Come to think of it, I'll bet that the generator armature-shaft is different too. Help!
Thanks in advance. The project continues.....
Al
DKhall
03-21-2004 17:00:55
 Re: MF50 Parts Wish List in reply to Yooper-Al, 03-14-2004 18:25:17
I have a 1962 MF50 that I put power steering on. I got all the doner parts from a MF65 everything bolted right on. Hope this helps.
Dale
03-15-2004 12:02:13
We have an auxillary valve that should fit your tractor, [email protected] or 920 295 3278, Dale
Part Time Farmer
03-15-2004 08:03:55
I have a tach drive assembly but the rear of your armature must be threaded for it to work. Let me know if you are interested.
PTF
