MF 165 brakes
Moye
03-19-2000 15:51:24
Was just doing a search on the MF 165 and found my old post of last fall about brake problems. I had no brake on the right side. Some asked for a report when I fixed it. Well, about 2 weeks ago, My students and I took it down. We found 3 problems. The worst was grease on the brakes. I am not sure if it was dif. oil or grease because it was very thick. I cleaned all the grease and oil off with brake clean, replaced the seals. I also cleaned the backing plates with a small side disk grinder with a flexable disk and 50 grit paper. However, when we put it back together, it still did not work. Finally traced this problem to the adjusting bolt hitting the foot rest on the right side. Probably not the right thing to do, but a notch cut in the foot rest support with the side disk grinder and now I have all the brake I need on both sides. Thought some of you might like to have this information. Maybe it will help someone. Moye
