Need Help with Hydraulic Leak on Pony
dans51pony
03-13-2004 09:34:22
I just finished rebuilding the complete hydraulic system on my 1951 Pony. I do not have a manual, but have received some scanned images from a fellow owner over the net. The problem is that I have a major leak where the lines attach to the control valve. There are two orings shown in the manual, however there seems to be other passages that would not be sealed by the orings. Well, I have actually found that this is true as the oil just poured out when I reassembled and started the tractor up to build pressure.
When I first took it apart, there were little bits of what looked like a paper gasket but barely enough to identify. Has anyone ever found a gasket at this connection? If so, it would help me alot for a description, sketch or photo.
Thanks,
Dan V.
