165 alternator
g cole
03-11-2004 06:46:44
Can anyone send me a drawing of hooking up a three terminal alternator. The simpler the better. Thanks
ray-s
03-12-2004 07:32:52
 Re: 165 alternator in reply to g cole, 03-11-2004 06:46:44
Link
This site has lots of wire diagrams.I sent you some other diagrams ,but not from here.ray-s
bob
03-11-2004 22:58:18
Big Deans website shows it all.
Thomas
03-11-2004 10:31:10
Connect one of the large terminals straight to the battery at the starter solenoid.
Connect the small terminal through a light bulb to the ignition position of the key switch. NB assuming it's a diesel you can't use the original switch, you need one with off, on, heat and start positions. The original switch doesn't have an 'on' position. Earth is provided through the mounting bracket. If everything is correct the lamp will light when the ignition is turned on and go out when the alternator is charging.
