101
Jr.
03-07-2004 05:03:16
Whats the difference between a 101 jr. and 101 sr.
Jim Griffin
03-08-2004 04:49:54
 Re: 101 in reply to Jr., 03-07-2004 05:03:16
We at one time had a 101Jr. w/ 4 cyl Cont, 101 Super w/ 6 cyl Chrysler 6 cyl Ind & 101 Sr. w/ 6 cyl Cont. The frame on the Jr was shorter than the other two.
Max(ia)
03-07-2004 12:59:16
Was interested in the answer for 101 sr & Jr differences. Saw a Massey yesterday that wasn't sure what it was. Looked like a 101jr, which I have ran, don't recall being around l01sr. It did have a 6cyl engine,side shields, no hyds, power lift, but the Decal said 44-6. Am I confused or what. thanks Max
Dave_Id
03-07-2004 13:53:21
 Re: Re: 101 in reply to Max(ia), 03-07-2004 12:59:16
The 44 & 44-6 are the next generation of the 101 Sr. The 44-6 used the same Continental F226 6 cylinder that was used in the 101 Sr.
Alberta Mike
03-07-2004 05:32:10
From what I know of them, the Junior was built on the same chassis (rear end, tranny, and front cast iron tub) as the Senior models. But the Junior used a 4 cylinder Continental flathead engine instead of a 6-cylinder one. The front tin on the Seniors was taller in size. The tractors looked a lot alike. The front tinwork changed appearance on both from the first early ones to the later production models.
Larry W.
03-11-2004 12:49:11
 Re: Re: 101 in reply to Alberta Mike, 03-07-2004 05:32:10
The Junior uses the same rearend as the SR, but the cast belly frame is 9 inches shorter. I know this because we used a Jr frame to get our sr lighter for pulling, the tinwork is the same height, grills interchange, tinwork is just a little shorter in length.
