M-H 50 HI ALT
Steve
03-06-2004 15:51:11
I recently purchased a Massey-Harris 50. I just found out that it's a high altitude model--for use above 5,000 feet.
What is the difference between a high altitude and low altitude model?
What happens if you use it at a lower altitude?Or how can it be changed?
Thanks, Steve
ChuckBergstrom
03-06-2004 16:41:05
 Re: M-H 50 HI ALT in reply to Steve, 03-06-2004 15:51:11
the parts book for a 50 shows only the sleeve and
piston kit as being different. these could have
possibly been changed already to reg altitude.Not
official but I doubt this is a big deal. incident
ly the sleeve set for a high altitude is the same
as for an L.P. tractor
Joe
03-06-2004 21:41:39
 Re: Re: M-H 50 HI ALT in reply to ChuckBergstrom, 03-06-2004 16:41:05
The compression ratio is higher(8.1:1 vs 6.6:1) for the high altitude engine. This also means that the timing and the carbureter adjustments are different. The original owners manual indicates that there should be special decals on the hood and a plate attached to the engine name plate that identifies the high altitude engine.
Joe
