1940 101jr
keith
03-05-2004 16:53:31
just trying to find out what the B stands for on the shift paten when i put it into (B) gear it does not do anything. to put it in that gear it is hard right and up. also there is a box on the front of the trany about 5 inches long with a lankage that goes to the govener what is it for
thanks
Alberta Mike
03-06-2004 06:45:33
 Re: 1940 101jr in reply to keith , 03-05-2004 16:53:31
Look on the front wall of the transmission on the drivers right. There is a shift rail cast housing there that should have a small cast lever sticking out to the right side. It has a hole in the top of the lever for a long rod with a bent end to mount to the lever, held in place by a cotter pin. If you have this feature, then you have a true twin power MH. You are probably missing the long rod between there and the governor, and maybe the linkage cam at the governor too. That setup clicks into place when you are in the "B" position (for belt work) or in 4th (road) gear. It somehow allows the basic governor setting to be bypassed and the engine can give you extra (but safe) RPM's for beltwork or road travel. You'll see that little lever move forward when the shift lever is in B or in 4 on the shift platform. Does your tractor have this little lever?
walter hoskin
03-06-2004 13:28:34
 Re: Re: 1940 101jr in reply to Alberta Mike, 03-06-2004 06:45:33
hi. you sure give a good description of twin power hook up. i have some old massey harris tractors,three of them are 101jr,two of three are ochard. keep in touch. walter hoskin 519 587 4551 [email protected]
Alberta Mike
03-06-2004 15:08:39
 Re: Re: Re: 1940 101jr in reply to walter hoskin, 03-06-2004 13:28:34
Orchards !!! Never seen a 101 Junior orchard, any chance you could email me a photo or maybe post a photo in the photo section here at YT? Where abouts do you live? I have removed the email hide feature from the above name link.
Alberta Mike
03-06-2004 06:47:52
Oops, I reread your post, you do have that little lever. If you are interested in the long rod and governor cam (which is probably missing) then email me, I will remove the email address hide feature from this post so click on the blue name link.
Bob
03-05-2004 17:03:42
B stands for "Belt". When you put the gearshift in that position, it changes the governer setting to alow the engine to run faster, hence "Dual Power".
