MF 1020 blowing fuses
Marcus
02-29-2004 08:05:27
My 1020 has dual in parallel 30A fuses going to the starter. The fuses blow very often when starting the tractor. Any hints as to what is causing the problem. I have checked the wiring harness and found no problems there.
The tractor starts and runs fine. Just blows fuses very often with the first start of the day.
John McPherson
03-03-2004 11:48:12
 Re: MF 1020 blowing fuses in reply to Marcus, 02-29-2004 08:05:27
It may be an indication that the starter brushes are worn enough to warrant replacement.
If all connections are clean and sound you might also want to check the condition of the battery, and solenoid. Especially if the starter is new. If voltage gets low due to pitting and wear, or a low charged voltage on the battery- current goes up accordingly.
