Big Dean-Hydro. Pump removal
Jeff-oh
02-27-2004 05:27:03
On a MF-65, does the hydrolic pump remove out of the top of the trans. case? Or is there another access panel?
I am looking at a MF65 where the lift drops in 20 sec. (2-bottom plow attached) after the pump is turned off. And I am tring to bound my repair costs on the high side.
Jeff
Big Dean
02-27-2004 09:17:26
 Re: Big Dean-Hydro. Pump removal in reply to Jeff-oh, 02-27-2004 05:27:03
In most cases the pump can be removed out the top opening under the lift cover. in some cases where they have multipower you will run across one the you will have to split the tractor between the transmission & rear center housing. If I can be of further help Email me.
