Question for Big Dean- ID massey block??
Ward WV
02-26-2004 18:55:25
Looking for someone to identify a 3 cyl. Perkins diesel block. It is supposed to fit a 35 but there are some external differences. Serial # CE22311U564258E. Underside of block stamped CUE15M.045(this would be covered by oil pan. Thanks for any help! Regards, Ward
ray-s
02-27-2004 19:07:55
 Re: Question for Big Dean- ID massey block?? in reply to Ward WV, 02-26-2004 18:55:25
Link
If you can reach this site you will see the explanation of your Perkins numbers. In case you don't get there. CE 22311 U 564258 E----- ----- -CE =engine family and type code
22311 = parts list number
U =country of manufacture code =United Kingdom
564258 = Engine serial number.
E = year of manufacture =1978..
Hope this helps.ray s
Big Dean
02-27-2004 09:53:22
Ward I don't remember ever seeing a serial number on an MF engine like that most have a something like a UA152 in the serial number the 3 cylinder Perkins engine was used in so many different applications & I don't know if the blocks were the same on them or not. You might be able to go to the Perkins web site Link or ask your local distributor.
