MF 97 clutch problem
novice
02-26-2004 16:13:39
I recently purchased an MF 97 which I undestand to be a MM 705. The clutch gave out loading it onto the trailer. I was told it was the "shifter ring" that broke. From the MM-19 IT manual (page 64, Fig 167, part # 22) it looks like the part comes in 2 half circle pieces. I was told it could be installed through the 4 bolt access plate on the side of the transmission without splitting the tractor. Does anyone have any experience at this??
marlowe
02-26-2004 18:21:18
 Re: MF 97 clutch problem in reply to novice, 02-26-2004 16:13:39
if you don't get the help you need hear post on the MM site. but then again you might have done that allready good luck
