MF35
Kris
03-17-2000 18:49:30
I just looked at a MF 35 at a dealer the other day. It seemed in really nice shape. I want a tractor to mow with and wondered if it would have live PTO. I understand some of these tractors have PTO's that keep running when the clutch pedal is pushed half way down while the tractor stops (not sure if it's the Fords or Masseys) My father had a Ferguson 30. Is this the same basic tractor only newer? I believe his had a Continental motor....does a 35?Any info on these tractors would be handy..... I've spent more time with Deeres. By the way, the dealer wants $3000 for it.
Clarence Carhill
03-19-2000 18:22:15
 Re: MF35 in reply to Kris, 03-17-2000 18:49:30
Kris... If the serial number has a "M" in it, it will have a two stage clutch... You will find the serial number on a little plate just to the left of the steering wheel.
Fred
03-19-2000 11:03:43
Kris, if you can drive the MF-35, engage the pto, put it in gear and take off. Push clutch in enough to stop rear wheel movement and look back and see if pto is still turning. Pushing clutch in further will stop the pto. This tells you whether it has dual or single clutch. It probably has a Continental gas engine if you look down toward the middle of the block below the distributor. Should say Z134A600 for 134 cu.incher. Look in front of distributor and see if it has a power steering Pump mounted there. All the more desirable. It can have 9000 hours on the tachometer and still have a lot of life in it if it was properly maintained. These things make it a good bit better than a TO-30 Ferguson. Only way to tell what shape it's in is put it to work.
Marvin
03-19-2000 06:48:48
Kris, Here in Southeastern USA ( GA) $3000 is a very reasonable price for a MF-35 if it is in good shape. My brother gave much more than that for a partially restored and painted MF-35 last year. You will definatley want live PTO I wouldnt want a tractor without it.
Rod (WY)
03-18-2000 09:08:23
I started life on a 9N and two grey Ferguson 35s. I grew up mainly on Massey 35, 65, 135, 150, 165 tractors. Dad still has a diesel 6 speed 1976 245 and an overdrive 8 speed 1988 240.
In my opnion the 35 was a big improvement over the 30. Both brake pedals are located side by side. Live PTO/hydraulics was optional--some 35s have it, some don't. 35s have two PTO speeds: ground speed and engine/540. 30s have a straight four speed transmission with one reverse. 35s havea 3 speed with hi and lo range, giving 6 forward and 2 reverse. Later ones could have Multi-Power--12 forward, 4reverse. 35s have two levers on the hydraulic quadrant. If I remember right the round one controls position, the short square one controls draft. Both tractors use Continental four cylinder gas engines: 129 cubic inches in the 30; 134 in the 35. Depending on the year diesels could either be a 3 cylinder Perkins or 4 cylinder Standard. The tilt hood on the 30 is a nice feature that 35s don't have. The 35 is a nice little tractor when equipped with live PTO. Unhandy without it.
Kris
03-19-2000 06:49:24
 Re: Re: MF35 in reply to Rod (WY), 03-18-2000 09:08:23
Thanks for the info Rod. How can I tell if the tractor has live PTO...is their a separate clutch to engage the PTO?
moye
03-19-2000 15:59:14
 Re: Re: Re: MF35 in reply to Kris, 03-19-2000 06:49:24
Kris, to tell if it has a two stace clutch, you really need to hook it to a mower. If it is at a dealer, get him to hook it up and try it. Once the PTO is engaged, you should be able to stop the tractor with the clutch down about half way and the PTO with the clutch all the way down. Without anything attached, however, sometimes the shaft will turn anyway, even with the clutch all the way down.
