serial number?
david
02-23-2004 19:57:55
found a massey? but has no tag or numbers no the hood. On the top of the rearend housing the number CM14826 is stamped. Is this the serial or housing number or what? Any help is appreicated.Thanks, David
Alberta Mike
02-24-2004 05:30:52
 Re: serial number? in reply to david, 02-23-2004 19:57:55
Describe the tractor, things like general size, rear tire size, hood (sidecovers), front frame (cast or rails), and any other features you might notice. As mentioned, the serial number will be hand stamped there too.
Davib B
02-23-2004 20:16:19
I don't think this is your serial number. If you look on the top right side of the transmission main gear case between the metal plate covering the rear end and the cast case covering the transmission gears, just below the PTO shift lever you should see numbers identifing the model , like 44G1RF for a 44 or another that would identify your tractor. You might have to steel wool a little rust and dirt from the numbers but that number is there. The serial number will follow the model numbers and you can find the year from that.
David B
