231 Wiring problem
stan
02-22-2004 19:54:01
I have a MF 231 I am trying to find out why nothing has power when the switch is turned on no lights light on dash. I dont have a manual with a wiring digram yet. I see some fuses on the left side of dash panel, all are good. There is a plastic box with a 8 prong plug going to it on the right side, but that does not have power either. Any thoughts? Stan
Christopher
03-03-2004 20:31:45
 Re: 231 Wiring problem in reply to stan, 02-22-2004 19:54:01
Stan I've got the manual if you want I can scan in the wiring diagram and email it 2 ya.
Regards Christopher
Ray A in N.J.
02-23-2004 09:41:47
Stan-, I would start checking all connections at the key switch and work my way out to the neutral safety switch. If that doesn't work check out the switch itself and make sure it isn't bad. the wiring is not very complicated on this tractor so if the conections are clean and tight I wouldn't rule out the starter switch.
