massey harris 44
cletus kipps
02-22-2004 17:48:22
Help!!! I need information on how to replace the oil seal on the front of the transmission; there's a shaft coming out of the front of the transmission leading to the clutch.. this shaft is split with two sprocks on it, with a chain around it; one of these shafts has to come out in order to get the oil seal on; there should be a way to do this without splitting the tractor. the tractor is a massey harris 44. thanks cletus kipps
JDBert
02-23-2004 13:56:13
 Re: massey harris 44 in reply to cletus kipps, 02-22-2004 17:48:22
cletus,
You have to remove the chain, then move the engine forward, take the sproket off the input shaft that goes into the tranny. Dont beat on the sprokets with a hammer, their cast and will break. then theres a seal plate with three bolts in it take that out and replace your seal, then reassemble.
marlowe
02-23-2004 14:12:16
 Re: Re: massey harris 44 in reply to JDBert, 02-23-2004 13:56:13
do what JD said but in the front of the engine where the two bolts hold the front down there are shimes under the bracket DON'T losse or mix them up or yopur shaft will NOT line up when you come to put it back togeather again
