mf 245 clutch dragging
Larry Dass
02-22-2004 12:07:45
Hi , I have a MF245, when i stop it with the brake, i cant get it out of gear, and it tends to 'creep'. I think this is caused by clutch dragging, but is it curable by adjustment? or will I have to replace the lutch?
Many thanks
Larry
Ray A in N.J.
02-23-2004 09:53:19
 Re: mf 245 clutch dragging in reply to Larry Dass, 02-22-2004 12:07:45
Larry-, make sure you have at least 3/4 of an inch of play at the top of the pedal- if not you should adjust. If thats OK just give it a workout for a couple of days and see if the dragging goes away. Sometimes when they sit for awhile the clutch will act funny due to weather conditions. I have a MF 65 I have had since new and the clutch outlasted the engine. Just make sure to keep your foot off the pedal when your not using the clutch since it causes heat and wear in the bearing and clutch plate.
