Hydraulic oil for MF 135
Murray
02-19-2004 17:05:03
What type of hydraulic oil should be used for the hydraulic's/ transmission/rear housing on the MF 135? Thanks Murray
Doug
02-22-2004 07:43:19
 Re: Hydraulic oil for MF 135 in reply to Murray, 02-19-2004 17:05:03
You should type in the term "M1103" in the search field above and read the discussions that come up. Massey hydraulic systems were designed to be used exclusively with heavy mineral oil and will not run properly with permatran. Massey sells its 90wt mineral oil under the designation M1103. It is expensive, but works. Apparently Wal-Mart sells something similar that also works well and is cheaper, but I have no experience with it. Good luck.
Tom
02-19-2004 21:28:10
MF Permatran III
