165 ?
Green 88
02-17-2004 09:08:31
I have a 165 Massey Ferguson Diesel and the PTO does not work. Someome said that a coupler between the pumps could be broke. The three point arms and the multi power still work. Does anyone know if this is a common occurance, and how big of a job is it to fix it? Let me know. Thanks
Thomas
02-18-2004 10:34:38
 Re: 165 ? in reply to Green 88, 02-17-2004 09:08:31
Drain the transmission and take the PTO shaft out from the back. They are designed to be the weakest link in the chain so that if the driveline gets overloaded it will break in preference to more serious transmission damage. If you are lucky it will have broken and you may be able to replace it without further intrusion.
Lee in MI
02-17-2004 16:13:13
First need to know if you have IPTO or reg PTO? IPTO has a lever on the side that only has ON/OFF and you don't use the clutch to engage, reg has Engine PTO/Ground PTO positions and you use the clutch to engage. There is a coupler/gear on the reg PTO just behind the main hydraulic pump. If the shift fork is worn out, you may not be sliding the coupler/gear on the PTO. I've had mine apart about three times now. Good luck with yours. Lee
