3 point will not go down
Richard in IN
02-16-2004 02:25:50
The 3 point on my 135 will not go down. When the tractor is not running, it will but when it is running, it raises by itself and will not lower. Any ideas? Thanks!
kjm
02-16-2004 18:59:12
 Re: 3 point will not go down in reply to Richard in IN, 02-16-2004 02:25:50
Richard, I had a 165D that did that and it was the roller on top of the linkage to the pump. Take off the right side cover and look in to see the linkage( we patched it with wire twisted around the linkage to keep the roller in till we had time to fix it right) Good luck
jack
02-16-2004 11:37:29
Just went through this with my 135, My problem was that a lever inside the 3 pt assembley got jammed out of place somehow, it happened when I got stuck plowing snow and the tracter was bouncing .If your problem was the same you will notice the position and draft levers don't seem to move smoothly and the pump will constantly be pumping . I got some more advise from BIG DEAN I can send you if you like.
Richard in IN
02-18-2004 20:52:48
 Re: Re: 3 point will not go down in reply to jack, 02-16-2004 11:37:29
Please email me the info or tell me where I can go to get it. Not familiar with BIG DEAN...sorry. What is the web address?
My email is: [email protected]
Thanks!
goofus
02-16-2004 10:03:28
Drain the oil, flush out with diesel fuel.It most likely will start working. goof
Thomas
02-16-2004 09:27:28
Your pump control valve is sticking, when it is running the valve oscilates to prevent sticking but even so it can sometimes stick. Take the pump out and fit a control valve kit.
goofus
02-16-2004 07:26:01
Go to Big Deans web site.
