injector pump timing
okiejones
02-15-2004 09:28:01
Just rebuilt a standard diesel. Not sure how to time injector pump. runs but hard to start and smokes. pump timing page in manuel is missing. help
Thomas
02-16-2004 09:39:29
 Re: injector pump timing in reply to okiejones, 02-15-2004 09:28:01
Which Engine? I'm familliar with the 23C (FE35), you get the engine position by inserting a 1/4 bar/ drill bit into a hole through the block casting backing onto the flywheel on the pump side - it's quite well hidden if you're not looking for it! Set the pump to letter G. If your're miles out then rotate the engine 1 turn and try again. ensure that you don't turn the engine backwards when locating the timing pin as the pump drives through a number of gears. You can remove the tacho drive to turn out the backlash with a big screwdriver. They are a pig to start at the best of times, if it's smoking have you had the injector nozles replaced?
If it's a 20C i've never done one, but I know it has to be spill timed, I'm not sure what that involves.
