Multi-Power and Headlights
JimG
03-16-2000 08:48:15
Thanks to all who responded to my previous questions! I took deivery of my 1966 MF
150 on Monday, and I'm having a ball with it. I'm prepping it now and I'll be painting it this weekend.
Question 1: What is Multi-Power, and how do I know if I have it?
Question 2:
My 150 has big square fenders with dual headlights mounted in them. The headlights are missing. I've searched the online tractor parts houses, and come up empty. Any idea where I can get replacement headlights?
Thanks in advance for your help!
Jim / South Texas
bbott
03-16-2000 17:41:31
 Re: Multi-Power and Headlights in reply to JimG, 03-16-2000 08:48:15
If you have multi-power you'll have a handle on the dash...the left side of the steering wheel that has a HIGH and LOW setting... or perhaps what's left of a handle and linkage... or a slot..... the linkage goes down to operate a 'pin' into the top of the transmission...
Multi power is an additional planetary OVER/UNDER gearset in the drivetrain. operated hydraulically via the linkage and a valve.... doubles the number of your speeds... also had a 'feature' where it 'freewheels' downhill in the low range...
Without multi-power, the Massey's can be hard to shift when theres' 'backpressure' from the rear wheels.. I think that's the reason the gearshift linkage gets 'knocked out of wack' on them from time to time.
Headlights.. I dunno... I guess I'd better not tell you where my barn is .. but then again it wouldn't do you much good cause mine don't work either.! Let us know if you find a source.
Best of luck with you 'new' tractor...
bbott
JimG
03-16-2000 18:08:16
 Re: Re: Multi-Power and Headlights in reply to bbott, 03-16-2000 17:41:31
Thanks for you help!! I apparently DON'T have Multi-Power on my 150. There's no slot in the dash. As for the headlights, a nice gent named Dean sent me the part numbers for the rubber o-rings. The bulbs are evidently an off the shelf item. I'll let you know how it works out! Thanks for all the help!!! Jim
