MF 1130
Lee in Tn
02-05-2004 17:25:33
I am going to an auction that lists an 1130.Being unfamiliar with Masseys,I did a search on this site.The posts here indicate this to be a good model.I have driven tractors 44 years,but only a few Masseys and never enough to be familiar with them.I would like to use it to pull a Gehl 1450 round baler,4 bottom plow,mower conditioner,and maybe mount a loader on it.Is it to big for this?I now use a 3020 deere for these jobs.I do not want a tractor so big it would be clumsey to use.Also what should I watch out for and what would be a good price?Thanks in advance,Lee
kjm
02-06-2004 20:31:31
 Re: MF 1130 in reply to Lee in Tn, 02-05-2004 17:25:33
Lee, That 1130 should pull 4-14 in road gear! We had one that ran 130hp on the dyno and would pull 8-16 in first high and high mp all day long. Good tractor,the early ones were hard on rear ends but they should all be scrape by now. Oh yea, just plug the return line at the fuel tank cheap HP.
John
02-06-2004 09:05:54
One of the best Massey's ever built. Other than the normal things you would look for on any tractor, make sure the park holds on a hill and shifts freely in and out. From lack of use the lift arms will tend to set up. Draft control will not matter if your plows are semi-mounted without an A-frame for a top link. Draft is controlled by the top link on an 1130. If this tractor has the pressure control style hitch (the one where the drawbar goes up and down with the liftarms) the chances of the 3 pt hitch working is better. Last one I saw sell at a farm sale went for $4200 in the fall of 2003.
chuckinnc
02-06-2004 05:57:16
The problem with the hydro was the draft position
it had problems, no one around here plows anymore
so it generally unused. The position control part
of the lift still is very reliable. I do my own repair work, I will agree it may not
be a good tractor to have if you have to depend on
the MF dealer, around here they change ownership
every year or two.
Clint
02-05-2004 19:34:31
I almost bought one a few years ago.A mechanic at a massey dealer talked me out of it. His claim was that the hydraulic system is very complicated, and can be very expensive to repair. Has anyone had any troubles with hydraulics on a 1130. He also said some parts were getting hard to find and obsolete.Good luck with it if you decide to buy.
chuckinnc
02-05-2004 19:09:24
Put it in gear and flip the multipower lever up and down while moving, if it works then the hydraulics are ok. Otherwize they dont have many
weak points. The 3020 has less than half the HP
of the massey & the massey has a long stroke engine, meaning high torque at low rpms thats also
somrthing the short stroke 3020 engine doesnt do
very well.
del
02-05-2004 19:02:47
Without looking up the weights I'd guess the 1130 to 4,000 to 5,000 lbs heavier than a 3020. about 45 more HP also.
