Tach drive on an FE35
Mike from Ontar
02-05-2004 11:09:07
I recently repaired the tractormeter (seized) and replaced the cable and tach drive on my FE35. While everything seems to operate smoothly, the RPMs seem to read about half of what I would expect. It is an AC Delco Tach, and does refer to a 2:1 ratio on the display. Can anyone tell me if the DELCO tach was the original or if there are two different tach drives for this tractor? I do not have a manual way of determining RPMs. Also should mention it is a 4cyl diesel, 1959 model.
This is a great, informative group! Keep it up.
Thanks,
Mike
Pete
02-08-2004 10:55:58
 Re: Tach drive on an FE35 in reply to Mike from Ontario, 02-05-2004 11:09:07
I just finished replacing my Smiths tachometer and cable with an aftermarket unit from Central East Farm Supply in Newcastle, ON. It looks different from the original, but works just the same. I also have a '59 FE35/MF35 with the 4 cyl diesel. If it helps, the Central East part number for the tach is S-41069 and the cable is S-41091
-Pete
Metcalfe, ON
Thomas
02-07-2004 02:49:14
The correct original tractormeter (tacho) should be branded . I think in was made by Smiths Instruments. Aftermarket replacements seem OK, I've got a Bepco on mine.
