massey 65 pto problems
hopper
02-04-2004 19:29:29
my 65 has a destoryed bushing between the two inner shafts that will not let the drive gear slide forward to engage pto. can that be repaired without breaking the tractor in half? any ideas?
Thomas
02-05-2004 11:00:45
 Re: massey 65 pto problems in reply to hopper, 02-04-2004 19:29:29
Yes, Remove the lift cover and the PTO shaft. Knock the split pin out of the shear tube, slide it forwards and remove the shaft from the epicyclic to the pinnion. You can now get at the PTO gears. Check the pump securing pins are not broken, they would put excesive load on the shaft which could cause the bush to fail.
Thomas
02-05-2004 11:05:51
 Re: Re: massey 65 pto problems in reply to Thomas, 02-05-2004 11:00:45
PS Then take the pump pins out, remove the pump and replace the bush on the bench. I would fit a pump kit while you've got it out, it's a lot of work if you ever need to do it in the future.
