WIEGHTS
MIKE
02-03-2004 14:09:11
HOW DO WIEGHTS FIT ON THE FRONT OF A 135
AND WHERE CAN I FIND THE MOUNT AND THE WIEGHTS
THANKS
TDom G (OK)
02-08-2004 19:13:45
 Re: WIEGHTS in reply to MIKE, 02-03-2004 14:09:11
Try Abilene Machine. They're a bone yard. They have facilities in Kansas and Texas.
Bill B
02-07-2004 16:40:17
Hi, They still sell the weights at a Massey dealer for about $50 apieace. I have bid them up to $40 at auctions before dropping out in south Pa. Bill
Don-Wi
02-03-2004 20:27:57
The 135 should have a wrap-around red bumper on it, about 6" wide x 1/2" thick, that's what the weights mount onto. Best place to look for weights is in the bone yard, espesially if they have lots of Massey's. They fasten on using a 3/4" bolt, with a 2"x2"x1/4" thick square washer and a square nut. The nut goes inside the hole in the weight, the bolt goes through the washer then the wieght. The hole is small enough to hold the nut, and you tighten it as much as you can. If the washer is too thin, it will just bend and won't tighten. The same weights fit on the 100 series, 200 series, and I think the 300 series, so there should be a few out there.
Donovan from Wisconsin
