massey furguson 135 wheel width
Dan
02-02-2004 17:24:49
I just bought a massey 135. now I need to transport it over 400 miles to my property. I have two questions; can I move the rear wheels in to make the width narrower so it will fit on the trailer I'm renting ( 6'4" inside). the width as it is now is 7'.
the second question is how much does it weigh. it has a loader and wheel weights.
thanks
thebigron
02-02-2004 20:20:38
 Re: massey furguson 135 wheel width in reply to Dan, 02-02-2004 17:24:49
The minimum width on a Deluxe, Special, And Orchard Tractor is 68-7/16 inches. A vineyard tractor is 51-7/8 inches. You had better take a good socket set to pull in the front tires, seems like a 1-1/8 or there abouts for those bolts, also a jack would be in order. Don't forget you can turn the front wheels around and gain (or loose) approx 4 inches each. If you have fluid in tires:front would be 65-90 lbs. each and the rear would be 452-645 lbs each depending on the sizes. Weight of a diesel is 3645. Don't know about loader or weights ( I assume bolt on). Drive careful.
Ray,IN
02-02-2004 21:37:12
 Re: Re: massey furguson 135 wheel width in reply to thebigron, 02-02-2004 20:20:38
Yep! And don't forget the new DOT chaining requirements.
Dan
02-02-2004 23:01:40
 Re: Re: Re: massey furguson 135 wheel width in reply to Ray,IN, 02-02-2004 21:37:12
Ray,
what are the new DOT chaining requirements?
John
02-03-2004 05:49:27
 Re: Re: Re: Re: massey furguson 135 wheel width in reply to Dan, 02-02-2004 23:01:40
It says..... ...
If your tractor is 10,000 lbs or OVER you must use 4 tie downs. One on each corner.
If under 10,000 lbs you still only need two tie downs.
If your tractor has a loader or other attachment it must be lowered and you must have 1 tie down on each attachment.
If you have items that are not attached to the tractor you need 2 tie downs plus 1 more for each 10ft. (thats 3 for 11ft...4 for 21 ft ect)
