Massy Harris 44 Front rim
Kevin Kozisek
02-02-2004 15:27:08
I live in N. Central Iowa and I'am sure having a hard time finding a front rim for the tracor. The other one went bad this weekend and it snowed a foot today. The rim is a 16inch 6-hole. The tire on it is 5.50X16 I measured the center hole and it looks like it measures 3.5 inches and the distance between the lugs are 3 inches apart. Does anyone have an idea where to find a rim or another tractor rim that will work. I heard that some WD 45 rims work. I called 10 places today and no luck yet. Any Ideas???
fasting
02-02-2004 16:01:13
 Re: Massy Harris 44 Front rim in reply to Kevin Kozisek, 02-02-2004 15:27:08
Problem might be because that is not a 44 front rim. 44's had a 5 bolt pattern. Someone has swapped out hubs & rims. Saw this before, I believe the hubs & rims from a MH SP combine will
fit a 44, something like a 92 or 90(?) combine.
Back to your rim need, you need to measure more,
such as on center, hole one & three, plus get the correct width. Check with Miller Tire, in the left column, Ed Miller has many old style rims,
since he supplies antique tractor restorers. I
realize the parked vintage combine is the lower
priced rim, but we don't know what was used back
when the original rims failed. Good luck.
