MH 444 Diesel
John
02-01-2004 16:29:53
We have a 444 diesel with the bosch pump without the attached governor. The internal engine governor ahs evidently demolished as there is no throttle control coming out of the governor. Will the governor weight assembly out of a 44 gas interchange?
fasting
02-01-2004 17:22:12
 Re: MH 444 Diesel in reply to John, 02-01-2004 16:29:53
John,
The 444G weight assembly should be a fit. Use the
cup assembly from the 277G as well,plus the rocker
arm & pin. Since we don't know what caused this
failure, better to install all the replacement pieces. The shaft will run horizonal on the gas, but the internal parts you need, function the same
Good luck.
