165 injector pump trouble
scruffy
02-01-2004 14:25:32
I was just moving round bales and the smell of deisel alerted me to a ever incresing leak at the injector pump.
On top of the pump where all the linkage enters the pump body where the speed adjusting screws are, there is presurized gentle spray of fuel from where the gasket has let go between the "cover" and the pump body. It had to be viewed with a mirror because the leak is between the pump and the block.
How difficult will be this repair? This tractor is not allowed to be out of service.
Does the pump require removal?
Am I going to have to fool with the timing?
I didn't see the bolts that hold this "cover" down, will the pump require disassembly? ohhh now I'm getttin' scared!!!!! !!
Big Dean
02-01-2004 15:40:10
 Re: 165 injector pump trouble in reply to scruffy, 02-01-2004 14:25:32
The pump does not have to be removed to replace that gasket. If you will send me an Email address I will email you a picture showing what is involved in replacing it
