MF-65 LP system question
Jerry C Okla
01-29-2004 10:15:47
The operators manual I have doesn't cover LP, my question; I have two valves on the bottom of the tank. I've been using the one toward the front as a shut-off valve and leaving the one toward the rear closed. Why two hand valves ?? I figured rear one was a reserve, but I've never run it out thanks Jerry C
raymond anderson
01-30-2004 08:02:27
 Re: MF-65 LP system question in reply to Jerry C Okla, 01-29-2004 10:15:47
One valve is the liquid and the other is the vapor valve. the one that has the hose going to the carb is the one you would open and close. the other you keep closed. I have a 135 MF that runs on LP for the last 38 years.
ALR
08-20-2004 10:00:33
 Re: Re: MF-65 LP system question in reply to raymond anderson, 01-30-2004 08:02:27
Help if you can. I need regulator parts for MF-65 LP. New or used. Where to go?
