Gas type for 1968 MF-135
Rod Carter
01-27-2004 20:12:01
This is a dumb question however I need to get an accurate answer. I have not been on a tractor since 1967 and back then we all used regular leaded gasoline on the farm. I just bought a MF135 and need to know what kind of gas to run in it. I was told by a friend just run 93 octane--do I also need to add a gasoline lead additive. Looked at all the discussion groups but did not see this topic. Appreciate anyone
s input. regards, rod
Randy
01-27-2004 21:49:34
 Re: Gas type for 1968 MF-135 in reply to Rod Carter, 01-27-2004 20:12:01
Rod: you shouldn't need 93 octane gas. Regular 87 octane should be enough. Which engine do you have, the Continental Z134,Z145, or Perkins 3 cylinder? The Z134 has a compression ratio of 6.6/1, the Z145 is just over 7/1. Don't know the Perkins but it is likely close to the others. Lead replacement wouldn't hurt but it's not absolutely necessary.
Rod Carter
01-28-2004 04:55:00
 Re: Re: Gas type for 1968 MF-135 in reply to Randy, 01-27-2004 21:49:34
Randy, thanks much for your reply, its appreciated. regards, rod
