BRAKES FOR 165
WAYNE
01-25-2004 14:21:53
I HAVE A 165 MASSEY. IT IS A 69 OR 70 MODLE. IT HAS SQUARE REAR AXLES. I NEED TO CHANGE THE BRAKES AND HAVE NEVER DONE IT ON THIS MODLE. CAN ANYONE GIVE SOME ADVICE.
Tom
01-27-2004 06:32:36
 Re: BRAKES FOR 165 in reply to WAYNE, 01-25-2004 14:21:53
Before you start this job, I would get a real MF Repair Manual, and a Parts Manual.
Thomas
01-26-2004 10:44:45
You need to remove the trumpets one at a time. Drain the transmission fluid and jack up the tractor about it's centre and fit wedges in front axle as for splitting. Remove all connections, linkage, brake rods etc from trumpets. Take the weight of the trumpet preferably with a crane. I've never tried doing them with a trolley jack as they are very heavy if they fall off. I also prefer to remove the fenders although this is not strictly necessary. Undo the ring of bolts and slide the trumpet off. When you sling it remember that the outside is heavier than the inside so pick up about where the fender bolts on. When you remove the left hand trumpet be careful that the crownwheel diff assy does not fall out. Remove the back plate (2 countersunk screws). If you've got dry brakes be sure to replace the oil seal in this. Replace worn components, if dry brakes clean all rust from splines, lots of copaslip, and reassemble. Be sure to balance the brakes when finished.
