Difference between 81 and 20????
PeteNY
01-24-2004 11:26:21
Guys, I saved either a 20 or an 81, and am trying to decipher what I have. Can't read the ser# (apparently it sat out too long) but the engine is free, and it is complete except side curtains and a front wheel...it has the older style mechanical lift, so I have pretty well determined it's not a 22...any ideas? Thanks, Pete
PeteNY
01-25-2004 15:59:53
 Re: Difference between 81 and 20???? in reply to PeteNY, 01-24-2004 11:26:21
Thanks guys, I'll get out and check that governor tomorrow, maybe take a wirw wheel to it to try to find the number! Who was the comedian anyway? Atleast when I try to be funny on herem I use my regular handle! Pete
STEVEN H
01-25-2004 18:22:09
 Re: Re: Difference between 81 and 20???? in reply to PeteNY, 01-25-2004 15:59:53
that would be me. But since i cant post a heading in a reponce i used the name feild for that.
PeteNY
01-26-2004 11:15:35
 Re: Re: Re: Difference between 81 and 20???? in reply to STEVEN H, 01-25-2004 18:22:09
Thanks...I have always been weak in math anyway!Pete
the differnce is.........
01-25-2004 14:10:44
61
ET
01-25-2004 06:20:04
The main differents I have noticed is the governor. The 81 has the governor mounted on the front side of the timing gear cover. I think it is a pierce goveror. The 20 has the governor mounted on the rear side of the tming gear housing and that is a novo governor.
Alberta Mike
01-24-2004 12:25:45
The serial number is there, you just have to scratch for it. It's hand-stamped into the upper machined surface of the transmission/differential housing. On that machined (cast) surface, go to the location between the transmission gear selector casting (that holds the gear lever) and the steel plate that covers the rearend gears. On the left (clutch) side of this machined surface the number is there but is probably filled with paint, rust, pigeon $#&% etc. Get a good wire brush and you'll find it, then post the number here.
parky
02-01-2004 09:51:22
 Re: Re: Difference between 81 and 20???? in reply to Alberta Mike, 01-24-2004 12:25:45
Alberta Mike, is there an Alberta based group of Massey and Massey Ferguson "nuts", that a person can hook up with to exchange tractor stories and problems??
I keep going to old tractor pulls at Stampede and have yet to see some Massey paint there!!
Alberta Mike
02-01-2004 12:39:52
 Re: Re: Re: Difference between 81 and 20???? in reply to parky, 02-01-2004 09:51:22
No real group that I know of, just the regular tractor type clubs like Leduc West, Irricanna, Westlock, etc. but nothing specific to the MH or MF brand that I know of. Do you get out to any of those shows? Where abouts do you live, sounds like southern Alberta right?
