TO35 Oil Pressure
spsteve - Walto
01-24-2004 09:56:03
My MHF T035 seems to have lost oil pressure. The oil and filter have been changed recently. The oil level on the stick shows full.
Should I suspect the oil pump?
If it is the oil pump, is this a major project to repair?
Thanks
51Pony
01-24-2004 18:08:40
 Re: TO35 Oil Pressure in reply to spsteve - Walton, NY, 01-24-2004 09:56:03
Hey Steve,
What Pete said! My Dad was real frustrated years ago with this '51 MH Pony. There was just a little crud up in the gage port. Check the simple stuff first before ya get worried about the bigger stuff. Us NY guys gotta stick together. I'm outside Syracuse at the edge of this lake effect. Pony's been working hard all week.
CH
01-25-2004 05:42:03
 Re: Re: TO35 Oil Pressure in reply to 51Pony, 01-24-2004 18:08:40
Hey '51Pony. We might be neighbors. You don't drive that MH down Seneca Twp now and then do ya?
51Pony
01-25-2004 07:46:28
 Re: Re: Re: TO35 Oil Pressure in reply to CH, 01-25-2004 05:42:03
Yes I do! Our wives work together, and I'm supposed to drop down there with beer, but it's been too darn cold. I figured I drop down with the MH sometime. What are you doing in the red section, aren't you orange? Well, ya ain't green so that's OK!
CH
01-25-2004 08:50:39
 Re: Re: Re: Re: TO35 Oil Pressure in reply to 51Pony, 01-25-2004 07:46:28
I believe my 245 is red. I try to keep an open mind. As a matter of fact, when I get done restoring these Allis B's,I'm thinking of a Farmall Super A. Unless I can find a reasonable Pony or '56 Fergy to redo. By the way, that's one fine lookin Pony you got. Hope to see ya soon.
PeteNY
01-24-2004 11:34:07
Steve, In this weather...anything is a major repair, hehe (Binghamton here,) seriously, make sure it IS your pump, check the fittings and the guage, then check your lines to see if any are plugged(had one plug an a Ford N once). If it is the pump, not BIG deal, you'll have to go in far enough to drop the pan(have to split her if it's like a Ford) then you can access the pump easily...should be able to get a rebuild kit at Marshall's in Honesdale, or Harpursville Farm and Garden, and rebuild it. Give you a chance to check the clutch and it's wear parts too! Pete
CH
01-24-2004 13:49:14
 Re: Re: TO35 Oil Pressure in reply to PeteNY, 01-24-2004 11:34:07
This is not the time of the year to have a problem like that. It was 10 below here, but your down south. About 95 miles.
PeteNY
01-24-2004 13:55:07
 Re: Re: Re: TO35 Oil Pressure in reply to CH, 01-24-2004 13:49:14
I'd be happy if it was 1 degree warmer here for every 10 miles South of you that I am!!!!!
