MF 165 Starting Problem
Dennis
01-20-2004 08:57:22
I have a 165 Diesel that the only way I can start it, is to jump it. It fires right up with jumper cables and runs good. I have put in a new battery that is the strongest cranking amps I could find that would fit in the case, along with new cables. even when I test the battery it shows full charge, it just wont crank the tractor over even on warm days.
jake
01-21-2004 11:28:42
 Re: MF 165 Starting Problem in reply to Dennis, 01-20-2004 08:57:22
check your cables and connections, i had a bad ground cable, same probs... if they are good i would suspect a bad starter like the other post did.
MF Kid
01-20-2004 15:44:59
Check your starter. It may have bad brushes or bad armature requireing more amperage to operate. While trying to start without cables, rap on the starter with something like a small hammer and see if it takes off. If it does then you have bad brushes probably.
