What year/model is my Tractor
TractorNovice
01-19-2004 13:35:08
Hi all,
I am trying to determine the year and model of my Massey-Ferguson tractor. I have recently inherited this and I no nothing about tractors, but I am slowly learning.
I am hoping someone out there may be able to help.
Some basic information about the tractor:
Color: RED
Engine: 4 cyl petrol
I have also located the identification plate which is located on the left-hand side directly below (not on the dash board, but if you can imaging its just in front of your left knee as you sit on it) the steering wheel. This is somewhat faded but I could make out the following details:
Serial Number I think: DL81891 (Stamped on ID Plate)
135 (Printed on the bottom of the ID Plate, don't know what this is)
On the engine I found the following name "BILGHROME". Under the sump I found "STANPART 301732"
I am trying to obtain replacement parts for this, hence the need to know the year/model.
Thanks in advance.
ALAN
01-21-2004 17:15:08
 Re: What year/model is my Tractor in reply to TractorNovice, 01-19-2004 13:35:08
I don't know about the other guys, but I'm afraid I need a little more info. Usually the model is on that tag you were describing. I can at least get it in the right family if you give us an engine model. It's usually found on the left hand side of the engine below the gen/alt & should start with a Z (if it's an old enough tractor that you can't find a model # on it). If it was "foriegn" built or an export model - well we'll see if anyone can help. GOOD LUCK - ALAN
TractorNovice
01-29-2004 18:49:58
 Re: Re: What year/model is my Tractor in reply to ALAN, 01-21-2004 17:15:08
Alan,
Searched for the engine model as you suggested but there is no numbering etc near/around the gen/alt.
I have however uploaded 2 photos of the tractor in the "Tractor Photo" Gallery under make/model of "Wish I Knew". Check this out if you have time it may help, I hope. ;-)
