1960 mf 35 diesel
RICK
01-16-2004 15:50:15
if i put a loader on this tractor do i have to have a secondary hydralic source (such as a pump running off the front of the crankshaft)
rick in Oz
01-17-2004 00:51:53
 Re: 1960 mf 35 diesel in reply to RICK, 01-16-2004 15:50:15
Rick it depends whether you wnat to be able to make simultaneuos use of linkage and loader. If you do want linkage and loader rather than either/or then you need another pump. However I have fitted loaders to 3 different 35 tractors with 3 and 4 cylinder diesels this year and the existing pump has enough capacity for farm work if its in good order. You will need a diverter valve which selects between linkage and external services . It is a simple push pull affair that mounts on the plate in front and to the right of the seat(remove existing plate). You then need a two spool double acting control valve to operate the two way rams on lift and tilt Plumbing is easy and takes about half a day if you have a rattle gun with reverse to fit the hydraulic fittings on the ends of the hoses. ( inside they have a left hand thread ).
RICK
01-17-2004 05:03:42
 Re: Re: 1960 mf 35 diesel in reply to rick in Oz, 01-17-2004 00:51:53
thanks for the info rickinoz . the way you described the set up is the same way my 150 is set up for external hyd. but i didnt know if the 35 hyd could handle it.(the 35 uses the 80-90 wt oil. the 150 takes the trans hyd. oil) doesnt a loader use trans hyd oil or just regular hyd. oil? rather than the thicker oil in the 35
Bob
01-17-2004 17:32:13
 Re: Re: Re: 1960 mf 35 diesel in reply to RICK, 01-17-2004 05:03:42
Older Masseys without Multi-Power originally had 80-90 hydraulic & transmission oil. Later models used 20-20W hydraulic & transmission oil which can be used in the older models.
Thomas
01-17-2004 14:59:26
MF 35 should use Agri MP trans oil, I think the normal spec is 10W/30, I assume you mean EP 80/90 which could damage the hydraulic system particularly when cold. It is possible to use the 35's system with a linkage and loader at the same time, you need to have the link arms in the 'raise' position and put position into constant pumping to raise, and lower to lower. Thus you need to have a frame such as the pickup hitch frame to stop the linkage going down before the loader, and a tap on the loader to lock it out for linkage work. Just connect the tap to any of the outputs on the lift cover, or to the trailer tipping pipe (if fitted).
William Bos
01-20-2004 17:09:52
 Re: Re: Re: Re: 1960 mf 35 diesel in reply to Thomas, 01-17-2004 14:59:26
We have a 1959 MF 35 (Standard 23c) with a loader and a front mounted pump. Our MF calls for a minimum of 90 hydraulic Mineral Oil. We use 100 in it because the 90 is a special order. You can't use a 10w30 type oil in there, it is not good for the pump!! 100 works fine, no problems in the winter at all!!
RICK
01-18-2004 09:32:17
right now im using bp 80-90 wt i purchased from the bp dealer.is this the wrong oil.i also use this in my to30
Bob
01-18-2004 17:31:50
 Re: Re: Re: Re: Re: 1960 mf 35 diesel in reply to RICK, 01-18-2004 09:32:17
80-90 was the reccomended oil for pre Multi-Power Masseys. It can be replaced with 20-20W hydraulic & transmission oil.
RICK
01-19-2004 17:37:59
 Re: Re: Re: Re: Re: Re: 1960 mf 35 diesel in reply to Bob, 01-18-2004 17:31:50
thanks bob i thought i had it right
North Florida
01-21-2004 17:07:38
 Re: Re: Re: Re: Re: Re: Re: 1960 mf 35 diesel in reply to RICK, 01-19-2004 17:37:59
Have an older massey and the local dealer cant tell me my model by my serial no# Any suggestions.
70s 3cyl diesel. lookin to add hydraulics North Florida
