hydraulics on a 44
chucky
01-14-2004 08:00:27
I have a loader on my 44 that is working real slow .I fixed all the plumbing leaks now i am thinking the pump on the left side of the motor isnt performing the way it should. how can those be checked out? thanks for all replys.
JC
01-16-2004 23:09:16
 Re: hydraulics on a 44 in reply to chucky, 01-14-2004 08:00:27
I would suggest buying a PTO driven high volume pump for a loader. What a difference it will make, and probably the "cheaper/more available" solution also.
marlowe
01-14-2004 08:32:54
the punp on the left is not a high GPM pump and if your rams are big this will make it lift slow but if you can not lift much then your pump might be wore. but as for slow thats just the way they are because of the low GPM and if it's cold out the oil might be to heavy
chucky
01-15-2004 06:26:51
 Re: Re: hydraulics on a 44 in reply to marlowe, 01-14-2004 08:32:54
yes thats the problem it hardley lifts itself. is there a rebuild kit you can get for them?
marlowe
01-15-2004 12:31:40
 Re: Re: Re: hydraulics on a 44 in reply to chucky, 01-15-2004 06:26:51
you can {not} get a rebuild kit the best you will do is find a good used pump and that is not easy and it has to be that pump also because the gear is on the pump no others fit. place a add in the classifieds on this forum some one should have one. i got a spare for my self. also watch ebay see some once in a blue moon for sale
