101jr/102sr
Robert
01-12-2004 20:25:49
Will side covers off a 102sr fit onto a 101jr?
ennismore.mike
01-14-2004 17:13:03
 Re: 101jr/102sr in reply to Robert, 01-12-2004 20:25:49
I have both a 1945 102 jr & senior , these are late model versions . The larger side curtains are different in length by approximately 3 inches . The smaller pannels appear to be interchangealbe. I am picking up a pair of reproduction panels - the longer engine compartment panels tomorrow , they are for my 102 senior.
Alberta Mike
01-13-2004 05:56:19
I've done it myself with a set of early Senior panels used on my early 101 Junior. By "early" I mean the style where the panel curve was very simple and there was only one panel per side (no extra panel under the tank cover). I assume the later panels would also fit but since the Senior panels are taller, the small panels under the tank would probably have to be modified or fabricated (which would be simple if you can do without the thumb latches). In either case, you would have to weld in some holding tabs on thge radiator support etc. to accomodate the taller panels. Email me if you wish and I will send you a photo of mine later today. I have removed the email address hide feature so hit the blue link directly.
