mf35/cracked exhaust manifold
KevJ
01-10-2004 18:33:05
mf35 4cyl diesel.Oops,tightened manifold too much,now cracked at end through bolt hole.Can I get this welded up or do I need to find a replacement.Thanks.
marlowe
01-10-2004 20:31:03
 Re: mf35/cracked exhaust manifold in reply to KevJ, 01-10-2004 18:33:05
they can be weld but if it's just the tab and it don't leak you might just want to leave it. put a flat washer on it and give it a try and if it leaks then you can get it welded
KevJ
01-11-2004 00:40:19
 Re: Re: mf35/cracked exhaust manifold in reply to marlowe, 01-10-2004 20:31:03
Thanks Marlowe.
