165- Aux hyd. oil return?
Don-WI
01-09-2004 22:40:15
I am adding hydraulics to my 165 to run the loader off a front pump, and am routing the suction line through the pto plate. I know I could just drill 2 holes in that plate and return the oil there, but are there any other places that the oil can be returned, through a plug or something? I am going to start tinkering on it on Sunday, so any help would be greatfully appreciated.
Donovan from Wisconsin
richard
01-11-2004 15:04:47
 Re: 165- Aux hyd. oil return? in reply to Don-WI, 01-09-2004 22:40:15
Put the return throuh the drain plug,masseys said this would cut down the tendancy for the oil to froth up , for occasional use it is ok to return to the filler cap.
CH
01-10-2004 04:28:10
I know I'm not going to give you the answer you want but removing the PTO shifter and plate and drilling a return hole in the plate would keep your 165 the way Ferguson intended it. Your parts manual will show you the location for the holes. Make sure you put a filter in the return line and refill your trans-hyd fluid after the addition is purged.
