1954 MH 44 Please Help!
Farmerbret
01-09-2004 20:55:10
I have just purchased a MH 44 gas 1954 model. I am not familiar on how the pulley works. It currently has the pulley but no belt and no hydralic pump. Is it possible for it to operate a lift and a bush hog? If so how? I was told it is a pulling tractor. Any information anyone can give would be greatly appreciated. Thanks in advance,
Bret
Gavin M
01-10-2004 10:24:04
 Re: 1954 MH 44 Please Help! in reply to Farmerbret, 01-09-2004 20:55:10
The belt pulley drive is is on a jackshaft (i.e. a 90 degree drive through a bevel gearset) from the PTO driveshaft. Engaging the PTO, as Steven mentioned, will also engage the belt pulley. The belt pully operates at 865 RPM, and the PTO at 534 RPM when the engine is at full-load RPM (1350), slightly faster at no-load RPM (1525-1550). However, I doubt a belt pulley will be of much use in driving a bush hog or any other modern implement. As you have probably noticed, the PTO shaft is mounted very high on the transmission case. This presents some problems with U-joint angularity and the adoption of a three-point hitch to the tractor. Massey Harris eventually used a very strong Cat. 2 three-point called the "Hitch-All". Earlier three-point hitches are reportedly weak and prone to breakage, even in Cat. 1 service. A problem is the top link. If the top link is mounted above the PTO shaft, the angle it works at is very severe and the three point geometry, which determines the draft and the correct operation of the lift, is poor. If the top link mount is below the PTO, then the geometry is much better, but PTO driven implements will generally not work, as they require the drive shaft to be in the middle of the triangle formed by the top link and the lift arms. MH solved this problem with the Hitch-All by making a top link with an oval in the middle for the PTO driveshaft to pass through. The problem was later (1956) completely solved with the 444, which dropped the PTO driveshaft below the top link mount. Hitch-All assemblies for 44 tractors are not common, and quite expensive. All 44's with factory hydraulics use an engine-driven (live) pump, gear driven off the camshaft gear. Unlike the hitch-all, they are commonly available.
The 44 is an extremely well designed and built tractor and will readily work had for many years. With few exceptions, the engineering is superb on the majority of the tractor's systems. Unless you wish to go to the time & expense of upgrading to a hitch-all, I would not jury-rig a TPH. Better to use a drawbar bush hog, as Steven suggested. Best of luck.
BONE
01-10-2004 17:15:37
 Re: Re: 1954 MH 44 Please Help! in reply to Gavin M, 01-10-2004 10:24:04
i have 3 point hitch with top link under the pto, but you only needed is a speical link, i made myself one. its 2 inches steel rod and i bent it into square shape about a foot wide and 2 and half foot long now i can hook up 6ft brush hog and it works like a heaven, only thing is i cant use the post hole digger but im sure it can be made to work..its pain in the butt but you can make it work easy.. its not diffcult.. SBONE
STEVEN H
01-10-2004 08:30:16
The Belt pully on the right side of the tractor is engaged by the lever with the grey ball on the left hand side of the platform. side that lever back to engage, but do so with the clutch in. the 44 can have a "hitch all" or as some call them a three point. but only row crop and high arch modles have the room for the hitch all. a hyd pump should not be hard to get for that as there are a few parts guys around this site. note, if your tractor is a standard tread than it will not be able to take a three point, but you can get a pull behind brush hog that is pulled only by the draw bar.
