HELP! TO-35 Runs Too good! 3000 rpm!
Kevin
01-08-2004 20:08:31
I just did a rebuild on a '55 MF TO-35. New Pistons, sleeves, head and all. Purrs like a kitten at idle of 380 r's. Grab the throttle and watch out! The first try it hit 3200 rpm and after arguing with all of the adjustments that I can adjust, the slowest high end rpm that I can get is 2850. The I.T. book says 2200 rpm. I removed the timing cover to see if everything with the balls and such was working freely thinking that I may have used too much assy lube and it all works real free. So, put it back together, detached the rods (per the book) and adjusted it again like the book said. Bam! 3200 again. How do I keep this brand new engine from sticking a rod through the side of the block? When running the throttle by hand, and holding the gov. rod, there is a very slight pull back as r's increase, but not near enough to pull the rather large spring back. Any help would be appreciated!
Thank you Kevin
Kevin
01-09-2004 05:22:01
 Re: HELP! TO-35 Runs Too good! 3000 rpm! in reply to Kevin , 01-08-2004 20:08:31
Whoops, Guess I should have asked this question in the "Henry Ferguson" discussion board - sorry! I still would appreciate any help from you Massey folks as well.
