Can't Start the MH Pacer
LeRoy
01-04-2004 11:32:18
I attempted to start the Pacer today using half charged batteries (all I had) before it gets cold again. I had put in some new coolant and some water in the fall and ran it for over an hour so the water pump would circulate the mixture.
It seems to want to start. Turns over, coughs and smokes a bit and quits. Either its the gas which was treated or the pugs are fouled again. Do any of you agree?
LeRoy
John
01-07-2004 16:34:40
 Re: Can't Start the MH Pacer in reply to LeRoy, 01-04-2004 11:32:18
Leroy Mine did the same thing,check your wires and see if they have been changed to spiral core. If so they don't work change them back to copper core wires which are oem. Also change the condenser and points. you can get them at any Napa store. Hope this helps John
