MF165 breather
Dennis
01-03-2004 23:58:38
In a previous message I was asking about the oil dipstick being pushed out by pressure, and it was suggested to check the breather, but I still can't find it. This is a diesel, older model with the exhaust on the left hand side. Any help out there
Alvin n Ms.
01-04-2004 07:15:58
 Re: MF165 breather in reply to Dennis, 01-03-2004 23:58:38
I will bet you two pints of diesel fuel that its the compression blowing it out. I have seen small springs attached, to hold them down. Won't hurt to check the road draft tube attached to the valve cover, you should be able to look at the bottom end of the tube with the engine running and see a little smoke . alvinnms
