MF 98 diesel tractor??????
Larry B
01-01-2004 11:33:06
I saw a tractor this past week while visiting family in south central IL. A MF 98. I am a IH man mostly but have owned five MF's in the last twenty years or so but never heard of a MF 98. It is diesel but the motor nothing like I have ever seen before. It had GM on it. I could not figure out how it work, could not find a injector pump or injectors. The generator ran off a shaft out of the back of the motor not off the fan pulley. Also had two aircleaner's on it comming thru the front of the hood. Also no 3pt hitch,looked like a wheatland style build tractor. Does any one know what I saw and anything on this tractor, year's built, hp, kind of motor? Thanks
Larry B.
01-01-2004 15:58:50
 Re: MF 98 diesel tractor?????? in reply to Larry B, 01-01-2004 11:33:06
The tractor is for sale at Clay county imp. in Flora IL a Case IH dealer (618)662-4422, www.claycoimp.com . It has new paint and decals 18.4-34 back tires. It's looks like brand new. Don't how many $$$$$$'s. They were closed when I saw it.
Nick
01-01-2004 20:31:49
 Re: Re: MF 98 diesel tractor?????? in reply to Larry B., 01-01-2004 15:58:50
As for price on the Massey 98 you described $13,500. If you look on the dealer's website there are two of them the other lists for $17,000.
Joe Ferguson
01-01-2004 15:21:17
Hi Larry
As mentionned in previous post it is a GM 3-71
2 stroke diesel engine. There is no injection pump the injectors are on top of the head and
they each include a piston operated pump which is
actuated by a rocker and push rod from the camshaft. The big box where the air filter is
connected on the side of engine is the turbocharger..it is an gear air blower that push
compressed air in engine to increase compression
and evacuate exhaust. There are no intake or exhaust valves in these engines. The throtle linkage was very tricky to adjust on these engines
because the control linkage was connected to each
injector. It remembers me many hours operating
these very noisy tractors.
Happy healty and prosperou$ new year
Joe Ferguson
John
01-01-2004 16:53:33
 Re: Re: MF 98 diesel tractor?????? in reply to Joe Ferguson, 01-01-2004 15:21:17
Just 2 things the box on the side is a supercharger not turbocharger and they do have valves but they are only intake or exhaust can't remember which
Joe Ferguson
01-01-2004 18:17:46
 Re: Re: Re: MF 98 diesel tractor?????? in reply to John, 01-01-2004 16:53:33
Corrections...
Detroit diesel (GM) 3-71 You'r right for the supercharger
turbocharger is driven by a turbine supercharger
is driven by gears
Early engines had 2 exhaust valves per cylinder
later engines had 4 exhaust valves per cylinder
but no intake valves
My memory failed after your comment I digged in dusty old techinfo manuals.
Sorry for the confusion
Joe Ferguson
Rlach
01-02-2004 18:14:11
 Re: Re: Re: Re: MF 98 diesel tractor?????? in reply to Joe Ferguson, 01-01-2004 18:17:46
"later engines had 4 exhaust valves per cylinder" : they are named "N" series like 6-71N vs 6-71(2 EX valves/cylinder)
Rlach
Harold
01-01-2004 13:49:59
Larry B, The tractor you saw was a Oliver super 99 diesel with Massey Ferguson tin on it. It came with a three cylinder, two cycle Jimmy diesel engine in it. Massey put their pants on it and called it 98. It was built around 1962. Hope this is of some help. ----- -Harold
Rlach
01-01-2004 14:43:50
 Re: Re: MF 98 diesel tractor?????? in reply to Harold, 01-01-2004 13:49:59
MF 98 was sold in 1959 and 1960; 500 were bought in a batch from Oliver; the engine is a GM-Detroit 2-cycle, 213 CID ( 3 cylinders of 71 CID each, or simply a 3-71 GM). It corresponds to Oliver 990 GM as tested in Nebraska(test 661) on july 7 to july 18, 1958.(Oliver Super 99 GM, Nebraska test 559, in 1955 seems to be rather similar to 1958 Oliver 990 GM). MF 98 arrived on the market before the Mini-MO MF 97. A very nice color picture of MF 98 is shown on top cover of the book : Massey Ferguson Tractors by Michael Williams.
Rlach
Rlach
01-01-2004 14:49:12
 Re: Re: Re: MF 98 diesel tractor?????? in reply to Rlach, 01-01-2004 14:43:50
Also : rated engine rpm ; 1800;
6 FORWARD SPEED(oLIVER USUAL)
Bare weight 10980 pounds
84.1 pto Hp for a fuel economy of 13.37 HP-Hour/gallon
Rlach
