Massey Harris 44 l.p. specail
Mark
01-01-2004 10:18:19
Did this tractor come with a 12 or 6 volt system. Also looking for a ring gear and brake parts for this tractor. Is there a place where you can buy the original wiring with the cloth like covering on the wires? Thanks for any help.
marlowe
01-01-2004 15:14:06
 Re: Massey Harris 44 l.p. specail in reply to Mark, 01-01-2004 10:18:19
6 volt + ground if your asking for starter ring gear just flip it over and use other side they pound off and heat up a little to put back on. what kind of brake parts?
marlowe
01-01-2004 15:13:26
6 volt + ground if your asking for starter ring gear just flip it over and us other side they pound off and heat up a little to put back on. what kind of brake parts?
mark
01-01-2004 16:16:55
 Re: Re: Massey Harris 44 l.p. specail in reply to marlowe, 01-01-2004 15:13:26
Looking for brake shoes and adjuster. Ears are broke off the adjusters and the shoe are wore to the rivets. Thanks
marlowe
01-01-2004 17:00:11
 Re: Re: Re: Massey Harris 44 l.p. specail in reply to mark, 01-01-2004 16:16:55
are you sure this is a special all the specials i have and have worked on have live pto hand clutch and disc brakes
mark
01-02-2004 17:18:10
 Re: Re: Re: Re: Massey Harris 44 l.p. specail in reply to marlowe, 01-01-2004 17:00:11
The decals look original and they say 44 l.p. special. That a different matter. I can't or haven't seen any decals like the ones that are on this tractor. I need to post a picture to see if any one has seen these before or if they were limited number like this or a test or show tractor decal.
Craig Noble
05-17-2004 01:33:27
 Re: Re: Re: Re: Re: Massey Harris 44 l.p. specail in reply to mark, 01-02-2004 17:18:10
I have a 44 LP Special with same decals! Email me direct. Thanks Craig
Gavin M
01-02-2004 10:58:37
I've seen several Specials with Bendix (Drum) brakes. In fact, I'm looking for the live PTO/double disk setup to add to a late ('55) Special with Bendix brakes.
